tbauer03
TRBOBOX
I noticed the other day when I got into ty the volt meter was at the half way point on the stock gauge, normally it is about at the 3/4 mark. I verified on DM from a file I ran just a couple days earlier that I am indeed getting less volts. before I was around 13-14 now I am around 11-12 volts. My dash gauges would occasionally flicker as well. I am guessing my alternator is one the way out since this drop occured so rapidly but I also read about some people not getting enough volts to their ecm and modifying some wire to increase the volts it sees. I did remove the ecm to change out the heater core before I noticed the volt drop. The battery is also new.
I briefly looked at replacement alternators on advanced's website and they all say they are 105 amps and 12 volts output, so i am also wondering if the 11-12 volts I am now seeing is more aligned to what I should be seeing and my previous 13-14 is higher than it should be.
Thanks
Thanks
