Vss
VermontTy
Support Our Troops
Re: Vss
They are different. A Typhoon runs a Borg Warner 4472 xfer case, and Blazer has a New Process 233. VSS's are different on the two of them. You need to look for one in a '90-'98 Astro / Safari or '91-'97 Bravada.
stlSY
Truck RamRod
Re: Vss
You usually catch this wire near the ECM, so if you find the pin config for the Ty, that will tell you wire color and location in the harness.
VermontTy
Support Our Troops
Re: Vss
The two wires you'll want actually attach to the DRAC; little white box mounted to the ECM. The wires you want are twisted together; they are (light green / black) and (purple / white).
