wastegate questions
tippmann243
alright guys im new, and ive been doing my reasearch
little background to what im going
lb4 4.3 bottom end
custom mpfi fuel injection
vortech heads
t56 tranny
and a syclone turbo kit
ive read that the stock waste gate, not controlled by the computer is good for about 10psi
more like 8-12 due to variation
is there any way to regulate that down any more withut having to buy a manual boost controller?
or what else would my options be id like to be around 6-7 psi 8 TOPS seeing as how this is going to be a stock bottom end with upgraded rod bolts
thanks for any help
-amrk
leroy
Re: wastegate questions
The spring inside the actuator controls the base opening pressure. You could probably cut the actuator and make it adjustable or change/cut the spring, if you have the skill.
Jim
tippmann243
true, but i also want to make it more accurate while im at it, because i dont want to be trying to run and only get 6 psi then driving home i get a full 8 psi
i could cut the spring down or replace it with a lightly weaker spring, that would lower the boost
thanks for the help, but anyone know how to make it more accuratei could live with a 2 psi +/- but not 3 or 4
smeagol
1 - you could get an actuator that has a lower base boost opening point (weaker spring)
2 - you could modify the stocker (lot of work, could screw it up too) and put a weaker spring in there
3 - you could put an external wastegate on the crossover with a light spring in there
1- might be hard to find a bolt in actuator that is lower pressure, price *may* reach that of #3
2- this is cheapest but most labor
3- this will cost you some money, some labor, but best performance & flexibility in future
leroy
tippmann243 said:
do you have any more info on this?
Use a die grinder to enlarge and smooth the wastegate opening. If you hog it out too much, the flapper won't cover the opening. It's not a bad idea to make a bigger flapper and enlarge the opening to size.
Jim
smeagol
Jim
FWIW, this would be an easy job for some turbo shops, but they'll charge you for it (of course).
Also, larger puck area means that more exhaust pressure 'fights' the spring pressure of the wastegate actuator. So if you port the wastegate and go with a larger puck, the stock actuator might decrease base boost level.
Jim's knows all of this I'm sure, just pointing it out for anyone not aware of these facts. It's not terribly difficult work, but there's more factors at work.
leroy
Good point Brian, and good to see you're still around.
Jim
tippmann243
thanks for all the help guys, i guess now its gonna come down to getting it all together adn seeing what the actual boost sets its self at and how bad boost creep is
-mark
