water in the ic
skipztt
boost
i have dutchty's lower ic (the alum one from his group buy), also an atr aux ic, shurfol pump and 3/4" lines.
i just filled this ic set-up with water for now. i was just wondering what the water should look like when its flowing??
when i have my cap off and the pump running. i can, somewhat see that water is moving and small bubbles from ( im guess ing the pump running) also coming up.
anyone have a video of what a proper water flow should look like??? can someone take a video for me? :):roll:
ViciousV6
400HP/550FTLB
Re: water in the ic
I had the ATR Upper with a shurflo and it blew a hole through the core leak 2 gallons of water into my motor and luckily didn't start up and seize the motor. Be careful if it acts up like stalls when tring to accellerate it could be water blowing into the throttle under minor boost.
Got the motor to run after all that and still went 12.0 on ultimate chip.
Ralph
ZavzTy547
Senior Member
Re: water in the ic
Ralph
I bought a used ic from a board member years ago that had a leak and made the truck sputter. Turns out it was used as a rats nest...
Flyin Ryan
hated cuz he drives fords
Re: water in the ic
Don't know about the new lower you bolted in but my stock upper ic and lower ic with 3/4 hose and shur flow pump always looked like your describing.. you could hardly see the water moving if at all and i'd have to imagine it would look the same with that new lower since it's larger and prob holds more liquid.
Tophatjimmy
Syclone FNG
Re: water in the ic
thats weird. with my stock upper and lower IC, 3/4" hose and a cheap Johnson Live Well pump, it humps the liquid right along.
I use a 30/70 glycol/water mix and it moves so quickly it actually froths a little.
Chest Rockwell
Re: water in the ic
I use a 30/80 glycol/water mix and it moves so quickly it actually froths a little.
Yeah, I notice the same thing with my stock upper/lower, ATR aux intercooler, and Shurflo pump. There's no question the pump's flowing water, it just hustles through.
Aeroking
e.i.
Re: water in the ic
i have the johnson pump, through both stock coolers, an aux cooler, and the heater core. and the little johnson pump moves the water pretty good, it looks like a swirling wave pool in the upper ic
skipztt
boost
Re: water in the ic
when i have the cap off, pum running, it looks pretty much how it used to with the stock lower ic and without the atr aux ic.
im just wondering if i might have an air bubble in it. :dunno:
you can tell its moving water, but as for as loud as the surflo pump is, you would think it would move it alot better then what it is now. :roll:
