Injected1
I have never made a post on this site before, but I would like to tell you guys my story and see if you can help.
I purchased my Syclone about 8 months ago for $4000. At that time it was a rolling chassis with a bed full of parts. It had been disassembled 5 years prior and been moved to two different states. I thought I knew what I was getting into -- :rotf: The motor and transmission had both been rebuilt. My plan was originally to put the truck back together as is and finally drive a Syclone. Upon receiving the build sheet on the motor, I noticed that they left the factory connecting rods in the motor.
From experience, I know that this is one of the weakest lengths in our 4.3 L V-6's. So now I have disassembled the motor and recompleted the build. Please help me make the right decisions on where I go from here.
To date I have accomplished the following on the chassis:
Body and bed removed. Frame painted with POR 15 first and then scuffed and painted with red polyurethane.
17 gallon aluminum fuel cell mounted under bed (still retains factory fill spout)
2002 Chevy Blazer rear disc brakes.
Energy suspension cab mounts
Walbro 255 in line pump
For the engine build:
Block bored .30 over and balanced
Lunati 457/268 Cam grind# 33504
TRW L2441 Blower pistons
2000 Vortec rods and heads redrilled and tapped to fit factory intake - Heads include comp cams, 610 lift, valve springs, 7.200 chromoly push rods, 1.6 roller rockers- self aligning (1318-12), 5 angle valve job with teflon seats and bronze valve guides
Cometic head gaskets
New oil pump
75# injectors
Pioneer SFI harmonic balancer
That's all I can think of right now but I am sure there is more. My future purchases will include some kind of computer, TCS performance 9/11 torque converter w/ 2800-3000 stall,
and I think a PT6776 dbb turbo. I am looking for my truck to be a mid to high 10 sec truck that will see about 100-200 miles a week on the street. I talked to a guy the other day from TD Autowerkes that said if I don't convert the truck to a T4 flange that it will fall on it's face at high rpm. Is this true? Is this combo that I have put together satisfactory for what I want. Anyone feel free to chime in on what they would recommend for a computer, turbo, or anything else that you can think of. Oh, I forgot to mention that I have a 93Ty that I am using for a donor truck for any parts that I might be missing. I know that I will be purchasing a 3 bar map sensor and building my own A2A intercooler setup to go along with whatever turbo that I decide to use but any help will be greatly appreciated :myclone:
I really need a mentor in the rest of this build so any takers feel free to let me know.
Thank you again,
Nick
p.s. Pictures of the entire build will be posted soon.
New oil pump
75# injectors
Thank you again,
Nick
