What did I break?
KyS10
So last night I decided to hotwire my IC pump. While I was removing the bracket that the relay is mounted to on the firewall I dropped my wrench. It landed perfectly with one end on the constant 12v wire that is just to the left of the relays and the other end on the steel IC hose. It only set there for a second but it was long enough for for the wrench to cause an arch between the two points. After that, a few puffs of smoke came out from under the MAP sensor.
After I finished the hotwire, I hooked it up to datamaster to see if my mishap had caused any problems. The truck drove just as before with the exeption that now it it throwing a code 43: ESC failure. From what I've read, this is usually caused by a bad knock sensor. Is it possible that I fried my MAP and would that cause it to throw that code. Would it still run properly if I fried my MAP or is this code most likely caused by something else like a bad knock sensor?
0966Sy
Code what?
If the map is bad it would most likely not run. Or run very long extremely rich as I've seen a aftermarket berg Warner map do. Does the boost gauge in the dash work properly? Also clear the code and see if it comes back
KyS10
Re: What did I break?
I figured if I had screwed up the MAP then it would most likely run like crap but it was worth asking. The factory boost gauge still works as well as it ever did. I guess I'll just reset it and try again as you said. Even if that fixes it, I'm still gonna be super paranoid about it. I feel like if it arced bad enough to cause smoke to role out from under the MAP then it had to damage something.
0966Sy
Code what?
I think the smoke you saw was from your arch, it just headed east before you saw it. Clear it and see if it comes back, you'll be ok. Btw get an aftermarket boost guage
KyS10
Ok. I hope you're right. I've got an aftermarket boost gauge mounted on the pillar already. I just mentioned the factory one because you asked about the one in the dash.
Turbotoyz
:banghead::banghead::banghead: lmao
Syclone22
The next time you get to work on your engine
just remove the negative battery terminal for
save keeping ..
KyS10
I usually do. It was kind of spur of the moment decision yesterday to hotwire the pump. I looked at it and thought "It'll only take 2 minutes to do this, what could go wrong?" I guess that'll teach me to be lazy.
Quickstop [UK]
Combating adversyty.
There are two fused wires that come off the back of the alt and provide power to the ECM and to the power block on the wall by the relays. They run underneath the map sensor and then into the loom before it splits and heads into to truck or provides power to the brick.
ESC 43 is most like due to you having knocked the wire connecting the knock sensor and maybe removing the connector. Is code 43 still apparent after you reset it?
The smoke was probably down to that fused wire coming off the alt and burning some old crappy insulation. It would be worth just checking that wire if you're concerned but if you have everything else working then you're probably ok.
DaveP
The dropped wrench caused a short to ground through the IC pipe. To complete the short through the pipe, the current had to leave the pipe. There is only one place the upper pipe touches the engine where the current coud leave: Under the MAP sensor where the pipe bracket is secured to the MAP bracket.
The smoke you saw was a resistive connection at the screw that holds the pipe to the MAP bracket.
Your Code 43 is un-related to the wrench-dropping.
I don't think this is very funny. We all have chit happen while working on things. If this had happened to me, I probably would have burned a hole in the pipe.
Quickstop [UK]
For posterity.
