what do you think about this?
msheller
Sy w/ pte52 kit, 2800converter, 3bar, pl chip for 50's, 50#er's, inline external pump in tandem w/ new factory in tank pump...vac off fuel press is 43, fuel is sunoco supreme(112) cut with half 94...cr42ts's gapped at .028....only 1 count of knock on a full pull...no WOT problems known
...2 small issues I'd love to resolve
If I hit the gas hard and fast, the truck gives one quick stutter, and then takes off...
Also, If i get on it about half throttle and then leave off the gas a little...and then get back on it again right away...it gives a little single stutter...b4 taking off
Idles fine and runs great otherwise...freakin' screams at wot w/ the dump open!
What do u guys think about these stutter issues? Almost feels like a misfire...
BTW, If i don't warm up the truck 1st, it'll misfire a bit w/ heavy throttle especially w/ the dump open...planning on trying the msd gm coil
thanx in advance 4 your help
Matt
blk00z28
Forced to by choice
Re: what do you think about this?
Matt
Well, if I hit my gas really fast it goes lean for a half second and then spools the turbo up and then rich like normal. So maybe thats what its doing, which I can see being somewhat normal in a way. (I'm sure it would take a long time to figure out how to make it not go a little lean when you first lay onto it. You'd have to sit and fine tune it for ever to get it to I'm sure.)
Sounds like the same thing when your in part throttle.
I never get into rpm's on a cold engine in any car. That can cause bad things to happen..;) I know what your talking about though, mine will do the same thing if I try and move a little to fast when its cold.
attackdog
I would think the MSD6 and a larger fuel pump may take care of the problem. I had similar problems in my truck and that took care of it. I also had to run stock plugs...
