Well i have a set of 99 vortec heads that have already been redrilled for the stock intake to bolt right up all you would ned to do is have your stock lower intake welded to cover the top of the vortec ports and have a new valve job done and install new valves and springs and what not, they are not cracked, i had them modified along with a CPI lower intake that i was going to install on my GT but got a set of 15 degree brodix heads and changed my plans so i really need to get rid of this stuff. Ill let you have the heads with all of the stock valve train with them for 350 shipped.
I also have a set of 92 L35 heads that have been fuly extrude honed on the intake and exhaust, have new stainless valves, stock size with crane spring that are good to .600 lift and titanium retainers and machined locks, Im not sure what these flow, but in a 92 Sonoma GT with a stock bottom end, these heads and a matching extrude honed CPI intake, reground stock cam(.550 lift) 35oo stall 4.10 gears and a set of slapper bars on the rear springs and a 100 wet shot of N2O, it had a single nozzle mounted under the TB, ther truck ran a 12.20 but hit the stock 5600 rev limiter at 1000 ft out, truck also had an aftermarket chip, but not a raised rev limiter. The guy i bought the head and intake from said with a rev limiter of at least 6500 the truck would have run 11.90's all day long. I bought these parts for the intake only, and have no use for the heads. Im not sure what they are worth, they also come with a set of comp cams pushrods and crane 1.5 aluminum roller rockers. If your interested in them make me an offer and im sure we can work out a deal.
my email is HotRodV6@aol.com
