bender
I am going to burn a chip with the ultimate bins on it, wanted to get opinions on the best version. My truck is all stock as far as heads, injectors, turbo ect. I have walboro, afpr, and 3 bar to accommodate chip, As well as non progressive alky I run 50/50 blend on.
I am wondering which of the ultimate versions I should choose from powertune plus, going to run it on my g3 with moates selector. Also wondering where the knock indicator on the ultimate gets its info, if it is from the bin is it something I could tap n to to run a knock led, if not I will probably build the old chitown knock led. I usually have lohhing going on, but would like a heads up display also for the knock. It starts to get to be a lot to look at boostgauge, wideband and logging all at once.
