At this point, regarding chip changes, you can't do much... BUT you will know your AFR, which is invaluable. So you will have any idea of how safe you are, how close your fuel curve is, what AFR your truck likes. You could adjust your boost level, fuel pressure and such, and see what changes it likes.
The stock injector & stock truck calibrations are very close, and any fuel pressure & boost changes you make should be all the changes you *really* need. Bigger changes would be necessary on the trucks running different heads/cams & turbos... and I'm hoping to make some sort of adjustment available, or perhaps several more fueling options... not sure yet.
If you do your own chipping, the possibilities are endless.
