Wont Start - Fuel or Ignition?
J_SULLIVAN
A&P slave monkey
Re: Wont Start - Fuel or Ignition?
Ryan said:
The truck was definitely stock up to this point. The injectors are all red top clickers.
One of the only sensors I haven't replaced yet is the knock sensor. What effect is that sensor in this scenario? Unplugging the knock sensor to test have any effect?
I feel your pain. I'm having the same issue too :rant:
dogboy
uk typhoon
must be wireing if you guys have changed all this stuff and it's still
farting around can it still be a componant fault?
Ryan
I've not touched this bastard since August 08. Anyone who had a similar problem come up with any ideas?
I need to order a new ECM and get started again.
WyoSyclone
I should run up some weekend and we could screw around with it for a day... gotta be something we can figure out.
djwaggoner
A bad O2 sensor could give you those wacky readings, & the ECM would compensate for the incorrect AFR... I can't see the UNI file, tho'.
& when_ever_ there's a weird electrical problem - start w/ cleaning up the battery ground terminal & check for any resistance between the batt post and the engine.
HTH
The_Bronze
I have family and a brother with a nice automotive shop there. I think that would make for a fun weekend if I can swing it as well!
Ryan
Wyo, Bronze -
That would be sweet if we could meet up and tackle it! I'm going to start getting reacquainted with this and try and narrow down the issue.
Bronze, what's the shop name?
