WTB fitting for IC plumbing
james#2274
One of my fittings sprung a hole and I'm looking to buy a fitting to replace it. Havnt had any luck finding it and not sure who makes it either. If you have one for sale or know where I can buy one that would be very helpful. Thankyou.
0966Sy
Code what?
Looks very possible it's a -12AN. My -10's measure 1/8" smaller than your measurement.
I'm pretty sure -10 is for 5/8 hose and -12 is 3/4
0966Sy
Code what?
Care to share pics of you IC setup? Did it get a hole rubbed into it or did the coolant eat through it?
james#2274
Re: WTB fitting for IC plumbing
FYI I have had this typhoon for about two months, so I'm new to this. What happen is about two weeks ago I started having a boost problem. About 6-7 it started to knock and the boost would shut down. I been trying to find what it is and finally I checked the ic and no coolent. So I added some and turned the ic pump on but nothing. Started taking all the hoses off tested the pump, turns on but does not pump. Than when I took the fitting off the air cooler on top of the motor I turned it over and found there was a hole. It was up against something else and had rubbed a hole in it. My theory is after all the coolent leaked out the pump got dry and burned up. I can get some pics up tommorow. The bad thing is it's my daily, I'm borrowing the wife's car and since she only works 1 mile away she is driving the ty.
james#2274
It's a shurflo RV pump.
I just ordered another one.
I was having a lot of problems trying to find the fitting until you told me the brand.
