IN WTB: Odd request. Fender cladding tabs
GarnetTy1473
Odd request, yes, I know. Went to put on my left fender cladding tonight and realized only 3 of the 6 tabs remained. While installing, 2 more broke off. 5 mins later, the last one broke on it's own. The right side is still in good shape. The truck had been previously hit on the LF back in 1995 and the cladding was replaced, but don't know if it was an aftermarket or what to make it deteriorate so much quicker than the other side.
So yes, anybody have a destroyed fender cladding that is willing to sell just the tabs? I would buy a new piece, but I just had them all painted and don't want to deal with trying to get the paint to match.
Throws
Re: WTB: Odd request. Fender cladding tabs
Use a chunk of a scrap bumper from a body shop. That's how I fixed mine.
-P
atkonkler
Is this your bush?
C'mon nothing breaks on its own! I know you looked at it wrong then it just broke! I know that's how mine breaks!
sycho
if for whatever reason you have your cladding off, always glue tabs, broke or not. what you can do is go to autozone and buy some plastic mud flaps, cut to size, and carefully glue to cladding. Make sure it perfectly aligns with cladding to fender, if not, you will have a gap. Now get to work!!! lol
T-Bone
Sent you a PM. I have a proven, classic (no tab required) 1 hour fix. Give me a call.
T-Bone
Are you gonna share, or is this top secret?
Nah, I will declassify it.
On the flat side of the cladding directly above the wheel, drill 1/4" holes at the 11 and 1 o'clock position (or 10/2 position) one inch in. Install a flat head-surfaced bolt from the underside with locking nut on other side (do not tighten yet). Cut a piece of wire roughly 3" long (clothes hangers work fine) and bend one end into a U-shape. Then bend the U-shaped area up at a 45 degree angle. Place around bolt and tighten to cladding.
Next, bend the fender end in the same manner about 1/2" from the bottom edge of the fender. Install a screw through the wire hole and tighten the screw into the fender. This will pull the cladding in and up at the same time resulting in a very snug fit.
You cannot see anything unless you bend over and look up under the cladding. 4 cladding tabs on the Aspen PS front were broken off and I devised this solution last year simply because the paint color would have been quite difficult to duplicate. Works great - no failure to date...see it at Nats.
13Pelle
I have seen Shaun's method up close and in person and it works quite well. I have a few pics that I'll try and post later if the is interest.
GarnetTy1473
Got the fender cladding back on, and looking pretty decent.
FYI: The squeegee's that you get with vinyl stickers work wonders as new cladding tabs. Just need to cut to the correct shape. And Loctite brand plastic epoxy feels as strong as steel once it dries.
