canadian
sy in progress
Have to say that the GM design is 100x better than anything I've seen out there and this will work with the BellTech lowered leaf springs. Haven't driven the truck, so I can't comment on it's new feel:
Here's a quick write up of the Xtreme swaybar on a Syclone. A
Typhoon *should* be the same, but I can't confirm it 100%.
Parts
* Xtreme swaybar setup, which should include:
* Swaybar (qty 1)
* Shock tower mounting brackets (qty 2)
* Swaybar endlink dogbones (qty 2)
* Grade 8 bolt, nut, lockwasher (qty 6 each)
* Axle mounts, u-bolts and pads (qty 2)
* Bushings (I used ES P/N 9.5158RC, qty 1)
Tools
* Quality 3/8 drill bit
* 90* drill adapter
* Stubby 15mm wrench
I started off by jacking up the rear of the truck and putting it
on some jackstands and then supporting the rear "pumpkin" with the
jack while I did all the work.
The first step was to remove the shocks on both sides to gain access
to the mounting pads that the upper dogbone mounting brackets would be
attached to. The mounts come from GM with a threaded hole to screw
the bolts into, but it looked kinda wimpy so I drilled them out to
accept a grade 8 3/8" bolt.
(mounting brackets are labeled "A", mounting bolts are labeled "B"
in the pictures)
The mounting brackets have one hole on the bottom where it attaches
to the bottom channel of the frame, and two holes on the back that
will attach to the rear upright of the shock tower mount. The problem
here is that you can't get a straight shot at drilling the holes
because the drill won't fit in the shock tower, and the rear frame
brace runs directly behind the shock tower so you can't come in from
the back either.
I went to Lowe's to find a 90* drill bit adapter, but couldn't find
anything there, so I stopped by Harbor Freight and for $9.99 I had
what I needed. I used a pair of vice grips to hold the mount in place
while I drilled the back holes. After drilling a hole I'd put the
bolt in and tighten it down to help keep things in the right spot
while the next hole was being drilled.
Once the two rear bolts were done, I went to drill the bottom hole
and found out that the Belltech lowered leaf springs didn't give me
enough room to get the drill in there, so I ended up dropping the
leaf spring to make it easier (also gave me the chance to cut the
u-bolts to the right length).
I made a carboard template of the mounting bracket and put that on
the bottom of the frame rail so I knew where to drill the hole. No
problems there. The drivers side is a little trickier because the
rear mounting surface doesn't extend all the way to the inner channel
of the frame rail because a wiring harness runs through there. Just
be cautious when drilling as you might end up going too far inboard
and end up with a "C" shaped hole instead of an "O" shaped one.
Once the brackets are in place, the hard part is done. Don't put the
shocks back on yet. It's a pain to get the bolts into the top hole
of the mounting bracket if the shocks are installed. The swaybar I
bought off ebay had all the nuts and bolts to those are what I used,
and YMMV. I fed the bolt in through the backside and used a 15mm
stubby wrench to hold it while I tightened down the nut. I left it
a little loose so it could move once the truck was on the ground and
everything settled.
Reinstall the shocks and attach the swaybar to the rear axle and bolt
everything back up, but don't tighten it all down yet. Let the truck
down off the jackstands and once you're happy with the way things look,
tighten it all up.
[edit 2008/03/22 - WB - sorry, no thumbnails any more. i'm lucky i managed to find the originals after the server move and hard drive crash]
http://www.warrenbowley.com/syclone/swaybar.zip
http://www.warrenbowley.com/syclone/drill.jpg
http://www.warrenbowley.com/syclone/endlink_1.jpg
http://www.warrenbowley.com/syclone/endlink_2.jpg
http://www.warrenbowley.com/syclone/endlink_3.jpg
http://www.warrenbowley.com/syclone/endlink_4.jpg
http://www.warrenbowley.com/syclone/mount_1.jpg
http://www.warrenbowley.com/syclone/mount_2.jpg
http://www.warrenbowley.com/syclone/space_1.jpg
http://www.warrenbowley.com/syclone/space_2.jpg
http://www.warrenbowley.com/syclone/installed.jpg
Parts
* Swaybar (qty 1)
Tools
* 90* drill adapter
in the pictures)
the back either.
everything settled.
tighten it all up.
