12.8 on 12psi!
bezerk
well, i was really getting pissed about not having a proof.
i went to drive 600miles for this (without a trailer).
my ty engine has a loud rocker, and the Kr goes bezerk about that, (why i haven't tuned it)
so first run was 13.1 (bad launch(
second run (12.8)woohooooo
what will it be with 20psi? and a good tuned truck??
i had a great weekend, Ryan was lucky to not be there at the night we went into bitbug!
lekkah pompah die subwoooversSSSSSSSSSSSSSS!!!!
Andreas
Re: 12.8 on 12psi!
Fix that rocker (I've read thou thats its a bit a ghost problem for you) and start turning the boost up :)
Will be nice to see your times then.
Oh BTW, nice collection och trucks in your sign :)
mrweelr
Re: 12.8 on 12psi!
Wow, I had to use 22psi on my stock motor to go 12.7, albeit with a very badly slipping torque converter. Your truck should fly if you get the knock issue sorted out.
bezerk
Re: 12.8 on 12psi!
yes, atleast this gave me the insperation, of taking off the loer intake, swap (again) all the lifters, and inspect what i will find.
you must know that Germany has no speeding limit at the highways, so i raced a VW GTI (200HP) at 165MPH from a roll..
mrweelr
Re: 12.8 on 12psi!
That's impressive, but please be careful. These trucks aren't made for top speed runs. Get a Mercedes, BMW, Porsche, Corvette, Supra, etc. for that stuff ;)
UR50SLO
V6+2=LSXCamaro
Re: 12.8 on 12psi!
How do you like that 61mm turbo? What kind of drivability vs stock? spool time ect...
Sounds good man!!!
Scott~
bezerk
Re: 12.8 on 12psi!
i have a 3k stall, spools up pretty good, but compared to my stock syclone it's just different.
the Syclone feels like a raped monkey compared to the Ty, but at higher RPM there is no compare.
if you daily drive it, i would go with a BB turbo, and a lower stall
blk00z28
Forced to by choice
Re: 12.8 on 12psi!
Did you type that right? I hope not..
But thats a nice baseline as to what you can improve on. I was at 17psi on my motor to run a 12.8 lol. Funny though, upping it to 25psi only netted me a 12.3... :(
