Re: 2000+ spindle/knuckle
AFAIK the 98-2004 4X4 spindle is the same for the larger front brakes. Not all S/T series in these years have the larger brakes. I don't have the part number, my fiche only goes to 94.
And while the 2nd gen calipers
are dual piston, the area of the combined pistons is LESS than the single piston 1st gen caliper. This alone will DEcrease braking effort with the same pedal pressure. What increases the 2nd gen brakes effectiveness is a slightly larger rotor diameter (12.75 vs 12.0) and about a 30% larger pad swept area. The"dual pistons" by themselves have nothing to do with the "better" part of the upgrade.
I recall a thread on here where a peep installed Wilwood dual piston calipers on the stock rotors and spindles. Wildwood has two different size piston calipers. The larger diameter duals have the same area as the stock caliper, and will leave the front /rear bias about the same, with everything else being left alone. The smaller diameter pistons will DEcrease the front brake effectiveness. These are intended for use with master cyl upgrades used with 4 wheel disc brake upgrades. The peep installed the smaller diameter wildwoods, and his brakes weren't as "good" as they had been stock. Which made sense to me. It's the AREA of the combined pistons that needs to be considered. The number of pistons means nothing. The area sure does.
Here's a thread with some info on the 2nd gen brakes.
