I know this isnt a s10 forum but I know theres alot of very intelligent minds here that might have some ideas. This is a motor swap I did around 2004. Engine is a 2000 4.3 v6 with 50k transplanted into a 1985 Olds Cutlass using a Painless harness and an oem fuel injected tank from a Monte Carlo TBI car. Ongoing misfire codes throughout the years, and 50k. Ive managed to fix them all but recently has started again, p0300, and is affecting driving at freeway speeds. Car is quick from stop to 60 ish but on the freeway above that it misfires badly, complete lack of power. Sometimes it will recover and drive fine for a while then misfire heavily again. Heres the history of what has been done.
Used an OEM vortec pump for the swap in tank
Lower and upper intake gaskets- within 3k of swap due to coolant leak on #6
Plugs, wires , cap, rotor- within 10k of swap
Updated poppet injector spider to the revised injector design- within 10k of swap
New High pressure fuel pump Summit Brand I think- October 2010
Plugs, wires, cap, rotor, coil, fuel pressure regulator- within 500 miles
Pulled distributor, checked for wear on the gear, looks very good no sharpened teeth
MAF, both o2 sensors, and the cat are original to the donor engine. I have an OBDII code reader that can display some data. I am at a loss of where to look next.
