Re: 4l80E +what year
1993 is fine.
Your gonna update:
All the pistons to bonded steel except for the 2nd piston.
New A and B shift solenoids
New TCC PWM solenoid
New PCS solenoid (you mod the valvebody when you do this, ask how when you do it).
Update the AFL. Actuator Feed Limit valve. Either Sonnax or Transgo kit.
Check your pressure manifold switch. If it fails the test, replace it.
Transgo HD2 shift kit(I have a special set of instructions if you do the whole KIT).
All new bushings.
Include a wide front stator bushing and no walk rear case bushing.
When you do the "no walk" case bushing, you MUST modify the lube holes in that new 4x4 shaft when you do it. It's in the instructions included with the bushing.
Get an all bronze thrust washer kit.
Put new sealing rings on everything.
Check bushing mating surface on the input shaft for wear.
Check bushing mating surface on the intermediate shaft for wear.
Check the bushing mating surface on the output shaft you use and check the bushing mating surface on the hub that's snap ringged onto the intermediate shaft where the output shaft rides on it. I've found those worn.
Feel down inside the direct drum where the sealing ring surface is for the center support. Any grooves, replace the direct drum. This happens when bushings wear out and lube is cut off or decreased.
There are waved plates in the forward and the direct drum. The early ones MUST be replaced. They are very prone to break.
You want the 12 tooth or high waved plate from the TH400 in both drums. They will NOT fail.
Use the "turbulator" steels in the OVERRUN AND OD.
BW High Energy grays (almost look green/black) when soaked in ATF or the Hoosier Reds throughout. Both are good clutches.
New 34 element sprag on the direct drum to replace the stock 16 element.
If your OVERDRIVE assembly is melted, it's where they ran it without lube with a bad TPS on a diesel truck. If you pull it out and it's melted, replace it with a 1999 and up setup. Much better designed roller clutch and input shaft.
The new input shaft will NOT work in an old overrun clutch assembly. Must be a unit.
New rear band and new front band. You don't necessarily need a wide new band. This band is ONLY use in manual second. It is not used in D or OD lever positions.
Lots of differences inside but nothing that you can't do and it's relative inexpensive to do since your rebuilding it anyway.
You'll be very happy if you do these to it. It will essentially become a new trans.
Bead blast the case after cleaning it with virgin glass bead. Clear coat it with a clear ceramic, let it dry, then douch the inside with hot water, hit it with a light degreaser and use a nylon bristle brush and clean the case out really good. Valvebody and interior. Air gun it again. DON'T PUT WATER ON A FRESHLY GLASS BEADED CASE!! It will be very porous and ruin the finish as the water soaks in and makes hard water rings. This process makes them look beautiful. FLP started doing this after I posted up pics and what I used. It just makes a VERY attractive product. Look at Jeremy Donovich's for an example.
I've built dozens and dozens and dozens of these over the years. This will prove a good working product.
