93 Ty 1064
Rob2000gt
I am starting a build on Ty #1064. I am planning on restoring every inch of this truck but staying under a budget of $3500 for everything but the drivetrain. At this point I haven't figured out what I am going to need or do to the engine so drivetrain will be the very last thing I do. I have a good doner for a lot of parts. I am going to do some mods that I really think will make it a better all around driver. I am planning on daily driving it when I am done so every bit of the truck has to be protected from rust and be easily cleaned. If anyone has any ideas or I'm doing something wrong or you know a better way please let me know.
Rob2000gt
This was my first step getting the body but not much left on it.
This is the way I bought it
Took the rearend out for the first step.
Worked on the leaf springs tonight. Took one side apart so I can epoxy the plates. I am doing one side at a time so I can make sure the I put them back together right. I will be putting epoxy on the leafs tomorrow.
Here is all my cladding I harvested off my donor
Rob2000gt
No lol. I am going to be pulling all the windows after Christmas. The winshield will be replaced due to being cracked.
I might take it off and put pony express on a bug shield in front of the hood
TeeTopZ
Re: 93 Ty 1064
$3500 is pretty ambitious. With that said, good luck. Update this thread with lots of info and pics, I'd like to follow and see how it comes along
Rice Eater
Re: 93 Ty 1064
Excellent, will be watching your progress. I assume you are very resourceful given your budget target.
How much did the donor Ty $?
Rob2000gt
Re: 93 Ty 1064
1064 shell frame and rearend was $500
1505 was purchased 2 years ago for $5800. I have been daily driving it.
Rob2000gt
I have cleaned and painted the brakes that I am going to use they are off of 01 camaro.
I have already cut my front spindles and designed my brackets. Just waiting on them to be drawn on computer and have cut out of 3/8 inch steel. Once they are made I have to measure for the spacers to put the rotor in the middle of the caliper bracket.
I got all 4 calipers and the rear backing plates for $58
SyTynet Admin
Administrator
Re: 93 Ty 1064
Rob, please use the edit button or complete your thoughts before you submit a post, you can put pictures and text in the same post together. Thank you.
Rob2000gt
Re: 93 Ty 1064
I have the springs u bolts lowering blocks and lower brackets done today
Total cost $15.00 paint supplies.
Rob2000gt
Re: 93 Ty 1064
Rear swaybar, links and mounting brackets done tonight. I am not happy how rough the swaybar is I might try to grind out the texture but not sure yet. I will decide when the paint cures.
Swaybar $13.99
Rob2000gt
Re: 93 Ty 1064
Bead blasted
Blackened and evaporust dipped
Painted flat black for protection
Every nut, bolt, and washer I touch will go through this treatment.
