Am I missing any gaskets to order?
wexy21
You're Boosted!
I just ordered all of these:
4.3L Performance Intake Gaskets (FelPro) FEL1268
SyTy Throttle Body Gasket FEL60826
Exhaust Manifold Gasket Set PHP66078
SyTy Plenum Chamber Gasket DNAMS38103
SyTy Head Gasket DNA5855
Oil Pan Gasket FELOS34502R
Head bolt set Victor GS33286
I'm putting my top end back together as soon as these come in. The heads and intake have been cleaned and resurfaced, waiting for me to pick them up. Did I get all the gaskets I need?
powercat6
Re: Am I missing any gaskets to order?
EGR gasket; unless you've deleted your EGR.
Timing cover seal; unless youv'e left the timing cover alone.
wexy21
You're Boosted!
Valve cover gaskets!
I don't need the EGR or the Tstat, and I didn't mess with the timing or waterpump. So I think I'm good right? No small seals or o-rings?
TY0618
Dist. shaft gasket? For a buck, its cheap insurance.
fuel line o-rings?
Intake gasket set almost always come with a distributor gasket. No exhaust manifold gaskets needed. Rubber valve cove gasket can be reused. Why did you buy fel-1268 instead of 1202?
warmpancakes
valve cover gaskets are reuseable , unless you ripped or lost them they should be fine
we dont use gaskets on the manifolds
