check these mat's out!
msheller
I ran diacom a few times tonite tuning the alcohol inj... On a short full pull to about 65mph my mat's started at 43degrees f and ended at 28degrees... that's the lowest yet!
It's probably about 30 degrees out now.
Matt
Loeryder
Re: check these mat's out!
I have had some skeptics tell me there is no way ht Mats dropped the further you wenmt down the quarter.
Glad to see someone else experiencing what I see on a regular basis.
Meth/Alky injection will actually drop your IA temps the longer you stay in it.
its funy to end the 1/4 cooler than you were in the stagin lanes.
give me meth or give me death.,..
msheller
by the way, before I ran alcohol inj, my mats would start at 90-100(unless I was fooling with ice bags at the track between runs....then I could get it down to 60) and rise to 140-190 on a full pull...that's no joke...Now, there's no ice bags involved and the mat's drop instead of rise the longer your in the throttle!! I think the alcohol coats and cools and the effect stays there after the pull...really works great to increase power and cool intake, but hasnt decreased knock retard as much as I expected it to...still trying/tuning different things tho w/ it...
Matt
Loeryder
Right off th bat you need to lower your Fp and decrease your spark plug gap to make up for the extra fuel in the meth/alky.
Chip tuning is the only way to get the full effect, but then you have to run alky/meth anytime you are in boost because it is a fueling substitute that is not accounted for by the ECM.
