click click click... how to determin what the cause is??
Flyin Ryan
hated cuz he drives fords
I ask because I rushed to get my truck back up and running for tomorrow's Hooters meet and no go.. nothing but lovely click click clicking for me!
So I ask how do you figure out what's causing this.. or how can I varify that the purple wire isn't the issue? I'd like to do this before I dick with the starter again because it's not one of my favorite things to do.. plus I checked with a volt meter and im getting a solid 12.3/12.5 volts to the starter power stud.
Here's what i've done previously if this helps at all
Boostedpimp said:
Relocated battery in the back... ran all 2 gauge to a flaming river switch.. ran 2 gauge from the switch to the alt and from the switch to the starter.
Stripped the shit out of the positive stud on the starter during this lovely process.. so I had to get a replacement which I did for $80 with a lifetime warrenty :)
Took forever to get it back up in there especially with the 2 gauge cable that doesn't enjoy being bent or shaped in anyway but it got done.
Cut the purple wire above the brake booster and reconnected new 10 gauge wire and ran it to the small peg on the starter since the original purple wire was fried pretty good
Any suggestions or instructions will be greatly appreciated :tup:
Ryan
theflash083
Re: click click click... how to determin what the cause is??
did you check the battery?
sounds like a dead battery to me.
Flyin Ryan
yea that would have been too easy man haha.. but yes checked the brand new optima with a volt meter
ViciousV6
400HP/550FTLB
Ryan
Take purple wire to a 30amp relay as the trigger, feed 12volts off the firewall post, and run 8 gauge wire or 6 gauge wire from relay to starter solenoid.
Call me if any questions 732-904-2701
theflash083
lol, well i didnt read that you checked it, im guessing that you checked the connections as well then?
autoaddictions
Is it out side??? Colder weather starters start to stick. Have a friend tap the starter with a hammer while you crank. 2. Voltmeter wont tell you if the batterys dead put jumper cables on it any way try to start. 3. both power pionts on the starter needs 12v to turn starter ground comes from bolting it to the block. If you need to be sure short the to bolts together with a screw driver see if the starter moves of just some sparks. Try those things.
I hope its not a pep boys starter if so change it im sure its dead.
QWERTYphoon
Motley Driver Award 2009
I had the same issues. I took the starter out, had it tested. It tested fine, but it back in and it worked twice. I pulled it out and tossed it. I replaced my starter with a CVR mini starter and have never looked back. Sounds like a battery issue if you get the click. I would try jump starting it, try another starter or replace the wires to higher gauge.
denny
Sound like the starter solonoid, try jump it with a screwdriver.
Flyin Ryan
Yes the truck is sitting outside :)
soo tomorrow morning I will try the following:
-crank motor while someone checks volts on power stud of starter
-tap the starter some
-run screw driver across both + studs on starter to see some action
-throw a set of cables on the battery and try a jump
Oh not a pepboys battery but a oem replacement
Thanks for all suggestions guys
