dash wireing help
mikester929
i just changet the cross body harness and dash harness on my 92 ty. i put all 93 ty harness. i was wordering if any 1 hade picks on how the dash harness ran becuase i kinda forgot how it ran can any 1 plz help...
BoostedSUV
Re: dash wireing help
you put a 93 dash harness into a 92? Be prepared for the headaches to start! Worst mistake I ever made, they're not the same.
mikester929
what do u mean it wont start i changed it all ecu under hood headlight u think it would be a problem
BoostedSUV
you changed the engine bay side of the harness too? The back side of the fuse panel on the firewall/engine side?
BoostedSUV
I didn't have any problems with it starting. I had problems with the wipers working, voltage draws, keyless entry being different etc. Does it crank and not start, or no crank at all?
BoostedSUV
I only changed the dash side of the harness and it wasn't the same as the one I took out. It also didn't match up wire to wire the same as engine side of the harness (not the engine harness itself, but the headlights/wipers/washer, fogs etc harness). Why did you change them in the first place?
BoostedSUV
it was doing like half turns the batt was dead
That's what mine started doing since I recently replaced the engine/ecm harness. That's usually a problem with the purple wire going to the starter solenoid, battery ground, or ignition switch plug is not seated properly.
mikester929
i rolled my w on w 93 ty over and brought it back and brought a red one that was on here from cali a 92 striped to the max
