Flyn Sy
Damn Qwik Old Guy
Ok, guys. I think that the Flyn Sy is more like the Ghost Ship Lollipop. My coolant disappears at an alarming rate, 1/2 gallon every 100 miles or so. I say disappears because
there is no trace as to where it's going. Here's what's been done so far:
- Visual inspection for obvious leaks. Block, water pump, freeze plugs, heater core, hoses, turbo coolant lines, etc. No coolant in oil or signs of coolant in trans fluid.
- Used a scope to check around bell housing. Checked the chassis to see if any streaking of any type. Zip, nada, nyet, no thing!
- 48 hour pressure test on cooling system. Lost less than a pound of pressure.
- CO2 test on coolant system showed normal. No CO2 in system.
- Scope showed no misfiring.
- Visual plug inspection showed nothing out of the ordinary.
- Compression test showed all cylinders between 160-165 lbs
- No idle or driveability issues. Truck runs strong.
This is the second major ghost issue I've had over the past couple of months. The first, if you remember, was the TPS problem, now this :banghead:. I have no hair left to pull out, having lost all of it with the TPS thing, now this . WTF, and I being punished for all of my transgressions I thought I had gotten away with? Any help from you guys and gals, would really be appreciated.
