help me brainstorm on knock retard please
msheller
I'm trying to decrease a slight to moderate knock retard issue. So, I was hoping we could brainstorm up all the possible sources of true and fake knock signal in an effort to come up with a comprehensive list for the board...
I'll get us started: low octane fuel, excessively aggressive timing, exhaust banging?, too much boost at too low of an rpm under too heavy of a load on motor, and... help me out here guys...
matt
mrweelr
Re: help me brainstorm on knock retard please
-Incorrect base ignition timing
-Poor boost control (stock turbo/wastegate)
-High IA and/or coolant temps
-Wrong plugs (heat range too high)
-Knock sensor too tight
-Bad ECM or low ECM voltage?
-Fuel pressure inadequate
-Carbon buildup in intake, heads, cylinders
-Broken motor mounts?
Those are just some ideas, take it FWIW. I spent a lot of time replacing parts on my Sy to reduce KR, with little luck. After doing all the major upgrades this past year, the KR basically went away. This is with the same bone stock 71K motor and crappy 91 octane. Now, KR only spikes to 1 degrees, occasionally, on 91 octane w/no alky spray. You can really feel it when the ECM is pulling out timing. I'm pretty sure the fix for me was the external wastegate and Blitz EBC (no more boost spikes). The solid motor mounts, Phil Long chip, and 50# injectors probably didn't hurt either.
Jimmy
Banned
When is it happening? Have you looked at your plugs?
msheller
w/ alcohol on...it happens most on downshifts/boost spike, part throttle accel, and non-brake stand launches....increasing the octane to almost full 118 sunoco supreme has reduced knock retard to max of 6 degrees on full pull, which in contrast to 16-17 max kr from last week on 94 is pretty good
how hard are motor mounts to do?
btw, are iac readings of 80-90 ok? It sometimes stalls... nothing else seems weird on diacom datalogging..no trouble codes
Matt
mrweelr
That's a whole lot of KR there for 94 octane. Something's not right. Have you checked your base timing with a piston stop and then double-checked again? Do you have a WBO2? What's your AFR range at WOT?
Do a search on my forum name and knock retard. I have never figured out my problem though, but I may have hurt my motor in testing trying to find the problem :(. It seems like me you KR is real, since race gas helped 10 degree of timing.
msheller
thanx 4 the help----the o2 is over 900mv at wot, we have checked base timing, but have not double checked it.
BTW I have had very rich running conditions periodically since the pte 52 kit etc. several months ago...and I've used alot of leaded fuel with the o2...do u think the o2 is ruined/could contribute to knock? could fouled plugs contribute to knock?
Matt
msheller
OK, what is "my forum name"?
thanx
Matt
mrweelr
You might try swapping the injectors and replacing the O2 sensor probably wouldn't be a bad idea either.
93ty475
Matt
at idle? sounds kinda high to me...
msheller
BTW, this help is great...once again thanx.
The rockers are stock.
I plan to do the ur6 plugs tomorrow(cr42ts delco in now) at .028, and buy new iac and o2 to try later... and the diacom runs continue... I don't think knock retard of max 6-7 per full pull will hurt it do u? The sunoco supreme is getting real expensive...turning my 3 times per week driver into my toy driven one time per week... but, I am exercising my new tranny very well while still under warranty though
Matt
msheller
I have only one set of 50# inj's...did you mean swap plugs?...THAT I can do
MATT
msheller
msheller said:
thanx...the more u know the better
matt
Wow,
dgoodhue--thanx 4 those links to the old kn retaRD threads... Really good info!
UR6 plugs going in finally tomorrow---I'll try to post knock retard results
Matt
