Sy#1991
Got the truck up and running with datamaster after doing new ngk plugs, taylor wires, cap, rotor ,coil, silicone vac hoses, johnson ic pump, rubber ic hoses, new t-stat and set base timing with wire unplugged. Before i did all the upgrades I had a rough idle (not misfire) but would idle surge a little, since the upgrades its still there but not as bad. If you blip the throttle a couple times it wants to stall out. On DM everything looks good except the S-term values are in the 140-148 range, which would be lean if I am correct. I sparyed down the entire engine looking for a vacuum leak and did not come up with anything. So I put on a fuel psi gauge to check fuel and at prime I have 42psi and 35 psi running (seems kind of low to me but have not checked spec. yet) Any help would be greatly appreciated. Sorry for the long post but wanted to give background info on it. Thanks
