ivanko barbell said:
SeattleSy#1255 said:
man, should have shaved your ass prior to going to the track. :lol:
Good run, have you considered alki instead of bigger injecters? Curious to what your MAT's are at the end of a run.
MAT's were very low under 110 degrees. I ran C-16 for better cylinder cooling, aquamist water injection w/ dual .6mm jets and the RPM A2A. The good gas an water injection was extra insurance against melting pistons. My aquamist pump seals don't like alcohol. They swell up and the flow rate drops by 50%. I use it more for lowering EGT's than boosting octane. I'll leave that for the race gas. I wouldn't want to run on alky w/ pump gas. There is a risk of poping the motor if the pump fails to deliver the alky.
I'm going to change out the knock sensor for a new one. I've heard they false knock when rusty.
I was reading the other day, and found out about some sweet shit. VP makes some race gas called VP import, rummored octane is 125. (listed as 120+). Cheapest I've seen is about 18$ a gallon, but it may be just what you need to break into the 11's with a touch more boost. Also, when you get the false knock, is it only during shifts? Mine is doing the same (giving me 6-8 knock retard, running 14 psi, alky injection, and xylene.), I've heard worn motor mounts can cause this, but I've yet to try the tie down strap to check.
