lbs of boost on what octane??
gjp
another post whore
Re: lbs of boost on what octane??
to many variables to tell. Truck tune plays a big part. at one point my truck was knocking at just 12lbs on 100oct. With a good tune I was up to 22lbs on 100 with 1-3 deg of KR. Alky help a lot too.
2kwik4u
Resident slow guy
I hear some people run 23lbs on 93 octane on a stock motor. I know others only run 15lbs on 93 octane with a built motor.
It really does depend....Whats your current setup?
RJE 93Green/Tan
ty high on psi
what do you mean by "tune"???
KETCH-UP
Tune is how well your truck is making power. Stock trucks can be in tune if the plugs, vacuum lines,turbo,injectors,IC system,timing at "0" and engine are all good.If all is good, the computer will show very low knock and 15 psi of boost on 93 octane. If your truck is not meeting this base performance, stop boosting and find out why!
SYO237
SyTy Registry
hit me up with your email so i can put you on the FL list. Im sure someone down in your area can help you tune your truck.
