Leave in drive & rev higher or shift into overdrive 1/4 mile
It's just a six
Super Member
Just curious what most of you guys do when racing the 1/4 mile.
Do you over rev the engine a little @ the end of the 1/4 mile, or do you shift into overdrive?
I finish around 108 mph.. but I have always shifted into overdrive.
I do not know what rpm that would be in drive going 108 mph? :tup:
Thanks
jwaller
Evil Genius/SyTy Guru
Re: Leave in drive & rev higher or shift into overdrive 1/4 mile
depends on your build but if your running 108 I'd say if you have an aftermarket cam and good heads then leg it out in 3rd.
It's just a six
Super Member
My engine is all stock 100% not touched with.
So you are saying I should shift into overdrive.... correct?
wantingasy
It's all stock and you're going through at 108?!? You must have an upgraded turbo or something right?
blk00z28
Forced to by choice
I'm gonna assume you have a build like mine?
I shift into overdrive around the 1000' mark I think.
108 on stock motor/turbo is not impossible with tuning. Heck we fell just short of 110 with same.
What I have found is the stock motor/turbo combo has a peak torque/hp down in the low/mid 3k rpm range. So I try to shift to keep it in that range.
I think your better off to shift personally.
It's just a six
Super Member
Thanks,
I had a stock turbo when I run 108 mph. 12.29
AFPR.atr aux cooler ,atr intake ,255 pump, pitbull chip, stock trans,converter,stock downpipe,3 inch catback exhaust,MSD 6A, full weight Syclone, spare tire removed & jack,3/4 tank of gas.
No alky injection.
FWIW
I've been experimenting here as I work on my alky tune. Installed a TC lockup sw and gained 1 or 2 mph. Tried shifting to OD at 1000' and gained maybe another 1 mph. My previous best was 100.x now it's 103.x.
In D (not OD) I think I'm pushing the RPM's a bit and the engine seems flat up there (still tuning don't forget) so when I shift to OD it wants to pull again.
QUICK STORM
B.A.M.F. BMW Tech
Don W. said:
FWIW
you in the 12s yet, Don?
Nope...:( Still only low 13's. Speed is up though, 103. Working on getting the alky to work and a miss at WOT. Not sure if it's my ign or the alky causing the miss. Believe me you'll see it here when I make it, even it just one run at 12.99. :)
It's just a six
Super Member
Have you gapped your plugs smaller? If you still got a miss?
Ohm out your pug wires also. Might have a bad one?
Ice down your intercooler before you run,if you have not already.
Leave a bag of ice on the intercooler when you race, just make sure it does not leak.
Pretty soon is the time to race when it's nice & cold & you should get into the 12's, goodluck!!!!
Haven't had the plugs out in a while. Set to .027 if I remember right. Miss is gone. (To much FP with the alky.) Maybe go to code 59 tune next year. 3" DP coming, I have the cat. Planning on 3" from turbo back. After parts are installed, planing on having someone look at it in the spring to help with tuning. Only 3 more race days this year, no 12's (yet!) but had great fun, won a few, watched my racer friends win a few. Short of winning the best part is meeting up with the "guys". Worst? Loosing in the first round. (That's only because nothin' broke yet:rotf: )
