Re: Lower Trans Line part number
I did consider fixing it... I was just hoping I didn't have to.
I have a trans cooler plumbed into this line already, and it didn't really look right plumbed into the lower line like it was, kinda flopping in the breeze. I'll probably just cut it and double flare it right where the gouge is. After looking at it, It'll probably look more 'stock' this way, and will hide the cooler hoses a bit more.
It is my attempt to keep it as stock appearing as possible, where it's practical to do that.
The only real departure from this is the chrome valve covers, although some GM cars had them. (Just not this one) I may go back to the black ones, but it looks so flat-contrast that way.
The rest is done with as close of a color match as I can find. The frame will be touched up with a zinc phosphate coating and the spray-wax stuff that the factory used. The fenderwells need to be re-done too, but I've never found the right color... it's a semi-gloss black, but it had a greenish/brownish tinge... not the same as the body color or the usual Eastwood underhood black. I may just end up hitting it with POR-15, since I can't find the exact stuff.
Otherwise, the ABS is there and intact, the stock air intake is there and will continue to be, and it'll generally look like OEM, just a bit shinier in places.
