Re: My Syclone finally at the track
I basically did some quick refresher reading and made a couple changes on the way to track to attempt raise my boost. A total half ass attempt.. I had planned to spend more time on it. My truck wastegate base boost ends up at 195 kpa or 13.8psi.
Keep in mind using $59 for boost you have to change desired PSI, as well as adjust the initial wg dc so that it gets to the higher boost level sooner, otherwise it will eventually climb to desired psi but it may not happen within 1/4 mile.
