Stock block casting??
denny
Is block casting # 14099073 a ty/sy ?
I searched this is all I found on casting 14099073
http://www.syty.net/forums/showthread.php?t=20725&highlight=14099073
1987- ’94 WITHOUT BALANCE SHAFT: In 1987, a roller lifter cam was installed, so the block was changed again. Two bolt bosses were added in the middle of the valley for the lifter retainer that kept the rollers properly located on the cam and perpendicular to it. This same basic block was used through ’91 for everything, and in ’92 through ’94 for all of the engines without balance shafts except for one small difference – some of the blocks came with four bolt holes for the tunnel style retainer beginning in ’92. There were several different castings used, including the 10105867, 10172756, 14099073, 14093683 and 10066011 with the two-bolt retainer, and the 10172756, 14099073 and 10066061 blocks with the four-bolt retainer.
Thanks
VermontTy
Support Our Troops
Re: Stock block casting??
Yessiree-Bob. Mine was 10066011. I think you could get pretty much any block; the block itself isn't SyTy specific. It's the nodular main caps.
