subwoofer box + pics need help
bezerk
i got it with the Sy and even bought an amp for it..problem is, it doesn't fit behind the seat if i slide it back completly. anybody know how i could make this work or is using this box as well?
thanks
Re: subwoofer box + pics need help
I don't have the dimensions, but I can see that its not going to fit. The part that wraps around the hump & tucks under the seat is too wide.
bezerk
it actually fits. but it's hitting the bottem of the seat at the side where you connect the wires. i tried cutting it off but it's made from fiberglass. might continue that progress but wanted some advice.
jpalmer
pull the carpet off, ifthat is not enough, then shave the box untill you have ample room, then reglass that area and recarpet. may take an hour of your time that way
