Re: torque converter lock-up?
dhorsman2000 said:
What do you use to lock/unlock your tourque converter and what is the best way to operate the converter while racing? Do you leave it unlocked/ locked up the whole time? Or just when you go into drive, or the whole time etc? :tup:
This would vary depending on the heads and cam you were using, but on a stock truck
I'd recommend locking at the 1-2 shift. This has been good for at least .1 on every truck I've tried it on, and .3 at the best.
I've seen numerous built trucks slow down when locking the converter.
Easiest way is to paper clip between the two outside terminals on the top row of the
ALDL connector.
later,
