ultimate question
ok, i just installed an ultimate for stock set up ,my ty is stock exept for a cold air intake,msd coil ,160deg thermostat,pit bull chip ,egr delete.i did a complete tune up, 3bar map sensor, afpr, walboro fuel pump. set timing at 0 deg and set fuel pressure at 50 psi. it runs ok but it smells lean and has a slight hesitation when taking off ,its bearly noticeable but its there. has any body had this problem? now if i advance timing will this help or not or what about more fuel pressure? any advise is apreciated thanks....
SY2932
Administrator
Re: ultimate question
Don't run another chip other than the stock one with the Ultimate or else you're asking for trouble.
