Need some advice, I installed Gilbert's propshaft and is having weird vibration.
It vibrate a little at 2k prm and like hell over 4k rpm.
What's weird is that speed dosen't matter, If I keep it under 4k rpm I am doing over 100mph with no vibration.
I remove the propshaft just to be shure its the propshaft, and yes its the propshaft, without it no vibration.
After rotating the front u joint 180 degree, the virbation is much less. Try rotation the rear of the shaft against the transfer case, it didn't help.
The shaft is not touching anything, I follow the instruction and cut the shift linkage 1/4". Beside the shaft is painted black, I would have seen marks on the paint if it was touching anywhere.
I am thinking of putting the stock shaft back on.
Thanks
Thanks
