white or grayish smoke while in Park only??
Flyin Ryan
hated cuz he drives fords
Ok,
Been daily driving the truck to work and back for the last few weeks during good weather and just yesterday noticed smoke coming from my cutout.. now normally I would assume it would be a head gasket or cracked head/block when I see white or gray smoke but what's weird is it will only happen if :
* cutout on dp is opened
* driven for at least 15 minutes, doesn't matter if your in boost at all or not
* only smokes when you put the truck in park, I can sit at stop lights all day in D and nothing
I not all three of the above is reached then it won't smoke.. Kinda has me scratching my head and has given me some hope it's not a head gasket etc so what do you guys think?
I haven't had time to check the oil pan contents or anything and won't until next week sometime so I figured i'd ask and get some ideas before hand.
QWERTYphoon
Motley Driver Award 2009
Re: white or grayish smoke while in Park only??
My truck smokes grey smoke when I first start it. I have been told it is valve seeds. $12 in parts and 6-8 hours labor. Do you have positive crank case ventilation? Have you messed with your PCV valves? Does smoke come from your valve covers?
Flyin Ryan
No smoke on startup here and I don't have any smoke from the valve covers but I just noticed that the front pcv valve is gone.. I mean it's just missing WTF
The hose that runs from it to the intake track is gone as well.... must of popped off and went out the fender well I guess.. I don't run a inner fenderwell on the pas side so I guess i'll have to hunt down a pcv and see what happens thanks for the idea
BigBadSmoosh
possibly tranny fluid leaking onto the exhaust..
just a wild guess.
