WTB Torsion Bar Delete and 700r4 crossmember for Sy
gmemony2
Looking for a torsion bar delete if anyone has an unused one, aftermarket. Same with the transmission crossmember, looking for an aftermarket one. JSM, RPM, not sure if anyone else made them besides those.
I know some say the torsion bar delete is not necessarily necessary, but if I can find one I'd like to use it.
DaveP's Ghost
Well-known member
What's a "torsion bar delete"? The torsion bar mounting cross member located behind the permanent frame crossmember is bolted in. If you don't need the torsion bars because you have coil-spring front suspension, unbolt the mounting crossmember and throw it on the scrap pile. Nothing more to do.
Goodgollyjosh
A torsion bar delete is a lightweight, aftermarket piece that is fabricated to replace the factory torsion bar cross member to retain any structural rigidity but does not accommodate the torsion bars.
