02 sensor lean-rich thresh hold
In BG chip page he mentions
0x0357 KCLOXTH O2 Sensor Rich-Lean Thresh. 0.500 Volts
Above or below whatever value is entered here will determine whether it is designated running rich or lean (for updating integrator). Leave it alone.
I was looking though the BBZA (my stock 93 Ty bin) and ATR Bin and they have this set to .350V Whats up with that? Should I try another bin such as bbzb that has this set to .5V
I know you said not to play with this value, but if I wanted to make lean chip for highway trips would this be ok, if I don't go too crazy with it? My corvette has a highway mode that lean out the mixture and I have found an increase of ~2mpg Will this ruin my cat?
smeagol
It will toggle it slightly on the leaner side - but remember that *anything* other than the .450 or .500 V value means nothing really, on the stock 02. It is accurate ONLY at that point, this is why I say not to change it.
ATR did it to try to compensate for higher fuel pressure settings really, IMO. Not the correct way to do it.
If you want a lean chip, there are a couple ways to do it.
1- Open loop chip, and adjust VE so it is leaner at cruise. This works out pretty well to a point.
2- this is untested, but a theory I have.
a) disable code 32 (EGR), but *do not* disable EGR operation
b) physically remove EGR solenoid, EVRV etc
c) adjust F28 BPC vs EGR %, so it is lower numerically when EGR operation occurs.
d) set it to open loop fueling (closed loop operation *may* run a bit leaner, but the open loop idea would work better IMO)
EGR operation will typically take place at low load, cruising conditions. EGR will be commanded via ECM/chip operation, but there is no EGR present. When EGR is commanded, the F28 value will lean out the fuel mixture slightly (versus EGR %). How much it can be leaned out ? Have to test to find out.
The 2nd idea is best, as the 1st way will lean out fueling just off idle, and hurt drivability. Running lean has the possibility of burning up a cat converter I believe. Running fat does as well.
smeagol
Also, F4 table is timing versus EGR %. A slightly leaner cal, with a couple degrees of timing may help mileage out a bunch.
sytyguy
Moderated User
Cool idea BG....gonna try it this afternoon. I had been using option 1 for sometime and had gotten good mpg (21+) results at the expense of some driveability though. I had been looking for a fool-proof way to get leaner cruise conditions without affecting other areas of fueling and this seems to be it. Will do multiple logs and post back here what I find.
Yah! I finally haven't something to try that's worth burning chips for again. I was starting to get withdrawal. :wink:
Hood
smeagol
Good deal.
If you have promising results, I'll create a webpage for it, maybe incorporate it into the Ultimate.
