trying to see what i should use. the block is going to be new. i also have nightdrivers pontiacs to put on the block. what should i bore it to?Syborg Twin Turbo said:depends on the bore of the block you have
what would you bore it to with the heads i got from you?nightdiver said:go with .20 or .40
the block is maxed out at 4.160. You will use this block in many rebuilds this way. if you go 4.160 or 4.155 you will have to use sleeves right after that
cool! i sent the heads out already. i have them flowing them and blue printing them for meSyborg Twin Turbo said:it all depends on the heads - take them to the machine shop with the block and they can tell you exactly what you need. It's better left to them to decide then trying to figure it out.
Windedv6 said:like Ed said...don't ask me why.
John
ed hess said:why .020 over ...long story ...dont ask.
ed
mike, what do you mean by that? what bore would you go with?ghettosled said:with the pontiacs you'll be shooting yourself in the foot with a 4.060 or smaller bore.
