09-412-08 cam card
ed hess
race or get outta the way
Anyone have a cam card for a comp cam 09-412-08 cam.
I dont have one and the guy at tech support for comp cams told me theintake centerline should be 108 degrees.
Well ive read the instructions over and over and out of 3 times doing this i get two at 102 degrees and one at 104 degrees. My tdc is right on as i had to set for the new pointer.
I havent watched their video that came with this degreeing kit but im bout to go home to do so.
DID THIS GUY GIVE ME THE CORRECT NUMBER OFF THE CARD?
ed
ed hess
well i now have a cam card.
I installed the gears with straight up on the marks. So wtf now?
I think i will go home and watch their video. Maybe i have just been looking at this to long and i'm tired...... shit one more delay.....
ed
E-Rue
ed i dont understand why your stressing over this.
i installed my 512 straight up with the marks (turned out great)
and ive heard that you do the same with the 412.
e
ed hess
Erue
I just have too much money in this so it doesnt hurt to take the extra time to check to be sure everything is correct.
For example, after reading the degreeing directions probly 50 times and watching their video last night, I am now sure i have installed this cam straight up, done everything correctly and I am getting a centerline of 104 degrees when it is supposed to be 108 degrees. So this cam has 4 degrees advance built into the cam using the straight up marks. And i am not using the zero mark next to the keyway but rather the other straight up mark as the directions written and on video say to.
So the question i have to ask now is.
Wtf is going on?
I do recall someone telling me they encountered this. They called comp cams and the tech guy told him they built all the 09-412-08 cams this way with 4 dgrees advance built into them by default.
I think whoever it was told em they just left it that way.
So now i got 3 options.
1 Go find that thread and make sure i remember that correctly what i tped above that he did. And leave it alone.
2 call comp cams and ask them if this is correct then decide to leave it alone.
3 do one of the cam gear mods to set the cam timing to true zero.
4 leave it alone, and get back to having a life.
ok so whos counting.
Anyway Erue its kinda like buying spark plugs. They always come gapped outta the box but we all check them anyway.
I think the only reason most dont check their cam timing is cuz they dont want to spend the $$$ to buy the wheel and the apparatus with the gauge!
ed
ed hess
found the other topic, i knew it was there cuz i started it.
another reason to check the cam.
I didnt want to have happen to me what did to brian green. His cam was 7 degrees advanced out of the box. he then modified the gear to set it back to the 4 degree of built in advance.
And with that im good to go.
Now i just gotta find out more about using hylomar sealant on these copper SCE gaskets to seal with these metal orings in the block.....
ed
