1.5" header tubing
TYTILIDIE
METH HEAD
I'm building a set of headers and I decided to use 1.5" tubing since I was having a hard time finding bigger collectors. I also thought it might be better for my first time around since I will have more welding room. The plan as of now is to run a 72mm turbo, anyone think the 1.5" tubing is a waste for a turbo this size?
It's just a six
Super Member
Re: 1.5" header tubing
1.5 will work fine.
If you want more of an all out power you would go a bit bigger.
Running 1.5" will get the turbo to spool quicker.
danimal95
1.5" tubing will be more that adequate,look inside the exhaust housing and see how small it has to funnel into,much smaller than than the added area of 6 1.5" tubes. There have been cars that have made well over 2K hp on tubes of that size,you will be fine
TYTILIDIE
METH HEAD
I dont expect them to look super snazzy like RPM's. I am using a mig welder 110 and mild tubing. They should look decent considering I did it in my garage though. I am going to try my best to not copy RPM for routing.
Sean Krupa
Moderator
Just out of curiousity, about how much $ after all is said and done do you think you'll have in the headers? If they turn out decent and provide some sort of performance gain, would you be interested in building more?
look. if you're goint spend some money let say 400 or more on tubing and everything else try to pay somebody to weld it for you, is you try it with mild welding machine it going to look like crap. you need a tic welder to do the job right. if i were you, i would just cut all the tubing and even spot weld to each connecting tube and then take it to somebody to tic welded it.that just my :2cents:hope it come out good .
TYTILIDIE
METH HEAD
So far I have spent $500 on the flanges and tubing. I am a pretty decent welder, they wont look that bad, just not little tiny welds like shops like RPM's. Even if they turn out to look totally amateur, I don't care, this is an experiment to see if I am ready to make something like this.
mattw
That shouldn't even be a concern.. There are only so many ways to make things fit in these tight engine compartments so chances are they will look similar no matter what you end up doing.. Do what works the best and gives you the best clearance even if it looks like something someone else has already done.. :2cents:
Slyclone
Well-known member
Whos providing you with the tubing or where are you getting your tube from?
TYTILIDIE
METH HEAD
I have the driver side header done. It ended up looking very much like RPM's, like you say Matt, only so many ways. I tried a lot of different routings but none really worked. Driver side header looks OK, about what I expected.
As for where I got my materials, I got all of it from various different places.
TYTILIDIE
METH HEAD
Sure why not. I warn you though, not the best looking header in the world. My welder only has two heat settings so I have to weld hot and just do little clicks at a time or I burn through really fast. I had to chase three holes but all in all I think it's going well.
Even though there are no holes, I may grind down and re-weld the chicken scratch.
MikeRenz
not stock
tough to tell from the pic, but does that upper primary allow you to put the valve cover on (with rockers/studs in place). And can you install and get a wrench/ratchet on the #1 spark plug?
Otherwise, looks like a great start. Grinding/cleaning the welds will make them look even better.
TYTILIDIE
METH HEAD
As a matter of fact they do. I put this together with a valve cover on and believe it or not, I built them around a spark plug and socket on it in #1. I can't use a ratchet but I can easily put the socket on the plug and use a wrench to crack it loose or tighten it.
