1 piece rear main cap question
ed hess
race or get outta the way
my bt block has 2 pc rear main cap. but the bt block has been machined for 1 piece seal. so looks to me like i can take the seal adapter off my existing block and just use it on the bt block.
thinking i can also move the rear 1 pc main cap to the bt block also. and then do align bore unless i buy a new rear main cap for the bt.
but are there stronger rear main caps or are they all the same?
whats the value on a stock block thats .030 over with 4 bolt main conversion?
bezerk
tell me what you are willing to sell, i got a truck that needs an engine.
$700 with mains and fresh overbore job, fully inspected. ARP bolts
ed hess
not really ready to list anything for sale yet as i still dont know about the combination but here is everything.
keep in mind the mods will probably move this post or lock it to another section since this makes it look like a for sale ad, and lately they like to bust my stones.
my intention of this thread is actually to begin planning my new build but here goes to answer your question.
all or part of the following....
Block with heads
Block has 4 bolt mains splayed
Screening bonded into lifter galley
Bored .030
Oringed deck
JE custom pistons
Arp mains hardware
Arp head bolts
Block has been notched for rod big end clearance (just like a bowtie block)
Block is not filled
Heads are vortech with receiver grooves
1.5 rockers comp cams rockers
screw in studs
chrome valve covers
upper and lower intake
lower is modified for vortechs
upper has egr block off plate and egr port welded shut
lower has egr port plugged w pipe plug
headers are a few months old from mpe
they are 321 SS
1 5/8th diameter tubes
changing plugs is a breeze with these
nothing is obstructed
removal on pass side does not require removing temp sensor
1 / 2 inch thick flanges do not require any gaskets to seal
crossover uses vband clamps
this is the easiest setup to r&r
these headers will not crack or flex under 1700 egt’s like atr stuff will
passenger side has wastegate adapter built right into the headers.
Wastegate dumps into downpipe
Garrett gt40 turbo with 42 wheel
Comp custom ground cam
Flat tappet hydraulic with lifters and pushrods
Timing gears and chain
DFI gen7 program to run this combination.
Duplicating this program would take hours on end to dial in and then fine tune
This combination has been totally proven to 9.93 et
Whats not included
Crank and rods
Oil pump
Water pump
Distributor
Fuel rails, injectors (84)
Sensors
Oil pan
Rear seal adapter
Timing chain cover
Anything else external to motor
Dfi gen7 cpu
Dfigen7 wideband o2 and module
Dfigen7 manifold temp sensor
ghettosled
SYTY SUPERSTORE
Ed, your best bet is to buy a new one piece cap for the bowtie block, and use the 1 piece seal adaptor off a core motor. Then have it line bored.
ed hess
mike
should i call you for this stuff?
ed
