10 sec + top end feeler
TYTILIDIE
METH HEAD
So I have come to realize that I no longer have an interest in running 10's. I was going fast enough on my old set up and am not sure I really feel like dealing with full on race stuff. This is just a feeler to see if I might get what I need out of this set up.
I have bowtie heads casting 14044883. These are 23* angle plug heads. They have been totally gone through, re-welded new valves/springs. Intake I believe is 2.10. I dumped at least $3000 in to these heads. Then there is a bullet solid roller cam, set up by Qbinkiller. I also have solid offset roller lifters with new pushrods, Jesel shaft mounts 1.55 offset lifters. The headers I built for this set up, the lower intake manifold which is actually a heavily modified stock lower. It matches the different angle of the heads compared to the stock heads and has been ported very nicely. And I also have black powder coated perimeter bolt valve covers. 76mm turbo. One must know that the headers will not fit a truck with stock steering box.
So you would get everything you need for your top end to run in the 9's at sea level. Everything has been calculated and matched to make this happen with this set up. In the Typhoon, I should run mid 10's up here at this altitude (6000 ft) with this set up. I have went through hell and back getting the heads to be what they are and none of this was cheap. I am going to ask $5000 for all of it. Or, I'd be willing to trade a built top end with vortecs along with all the other stuff I am selling plus some cash. I don't need to sell this all whatsoever so getting something out of it for me is important as even what I am asking is at a loss.
Bullet Cam
Crower lifters
Manley pushords
Jesel Shaft mount rockers
Aluminum fully built and ported Bowtie Heads
Custom lower intake
Custom perimeter bolt valve covers
headers
76mm turbo GT42
$5,000
And here is a link to the build thread
http://www.syty.net/forums/showthread.php?t=99205
I will NOT sell my bottom end.
mai-tai
Re: 10 sec + top end feeler
:thumbsup:ill trade you for my stock top end, stock turbo, stock cam. :thumbsup:
TYTILIDIE
METH HEAD
I should probably clarify what I need to do a trade.
Good cam to run 67 mm
Vortec heads already modified with 2.02 and springs to match cam
Modified lower
1.5 or 1.6 rollers
New lifters, stock is fine
Preferably center bolt sheet metal valve covers
67 mm gtq or bullseye equivalent
and 1000.
Pretty fair trade I'm thinking.
TYTILIDIE
METH HEAD
Still looking to trade or sell this set up.
If I trade, it would be for this list only, NOTHING ELSE.
FRESH Vortecs ready to run with 2.02's
Decent matching cam
67GTQ turbo or similar (nothing smaller)
Stock exhaust manifolds w x/over NO CRACKS
Roller rockers with minimal wear 1.6 preferred
Fresh bored stock throttle body
$1000
