101 octane vs 105
spooldup
Super Member
Hey guys. Before i sell my truck i want to take it to the track. I have plans to go tomorrow so i was doing some calculating. If i run 5 gallons of xylene to 10 gallons of 94 i get 101. If i run 100 plus the same xylene i get 105. Will the 4 points really matter when you are running high ocatne like this? I figure if it's minimal at this point i might as well save the dough for lunch or something.
100in6
100in6
you might check on just buying some race fuel. around where i live buying xylene and toulene is actually more expensive than just buying race gas. if you still have a catalyic converter don't use the leaded and try to find the unleaded. or if you are close to a small airport you can get avgas in 100 low lead. race gas seems to make more power
:D have fun
ghettosled
SYTY SUPERSTORE
run c16 then just drain the tank after the track.. it wont hurt your o2 or cat. and it will make a difference if you have any detonation present.
100in6
100in6
hey mike...
leaded won't hurt the CAT??? i know it's no biggee for the O2 but I thought runnin leaded really loaded up the cat
les
ghettosled
SYTY SUPERSTORE
as long as you drain the leaded gas out after the track and drive the truck home, it should burn out. We run leaded gas all the time through cats, and have never clogged one up. You just can't leave it in there and drive around for weeks then let it sit.
100in6
100in6
and it still works and will pass an emissions test? guess so since calaifornia has emission testing.
What do you know...I learned something new
thanks for the info mike
les
