Just thought I'd kick this off, I'm sure there are others who are looking for different recipies :wink:
I am wondering what everyone thinks would be the best way to build a ty that would remain as stock as possible that would meet the following criteria:
Runs 12.5 @110mph in the quarter, on *91* octane fuel.
Passes the Ca sniffer tests (no big cams)
Looks/sounds as stealthy as possible (giant front mount air/air intercoolers make this tough :wink
Is "100k miles reliable"; i.e. if you built up a new motor with these mods you'd hope to be able to drive it for years because you wouldnt be overstressing it thermally/mechanically.
Does it with carefully selected parts, not just by throwing everything on the planet at the problem.
Has a minimal stall convertor to retain everyday driving manners(i.e. the lower the better, but assumed to need higher than stock)
My thoughts about this center upon creating a motor that will rev higher and create more horsepower than stock, not simply creating a motor that tries to make a boatload of torque by 4k (which breaks driveline parts). I would imagine that you'd want a good turbo/downpipe setup like the PTE (what trim?), ported L35 bolt-on heads from McCoy, perhaps a mild cam, and? All of this backed up with an Ultimate w/50's or something similar and the "assumed" mods like big fuel pump, aux cche, etc.
All this begs the question, is this easily done using a stock shortblock, or do you have to do a build with splayed 4 bolt mains, strong rods and pistons, bowtie block, etc.
If you started with a dead stock truck, and had access to any parts you wanted, what would be the best route to take to accomplish the above? We're talking about building up a motor carefully here, not just showering it with parts (which is fun :smile
Thoughts?
Thoughts?
