12.7 knock!!!
S
SYCOSIS
Guest
Don (#0112) fron Kansas city came over and logged my truck on a run and discovered it had 12.7 knock on turbolink during entire run. Here is the weird part... the timing stayed at 15.1 degrees. ECM did not pull out any timing with the knock issue it did however limit boost to 10psi during run. I am gonna do a complete tune up and purchase a laptop with datamaster or turbolink so i can begin logging. I dont want to kaboom my 35000 mile SY.
Anyone have any thoughts on this?
ed hess
race or get outta the way
as i recall if you have a kenne bell chip it wont pull timing out when you you have knock counts. So what chip do you have?
ed
Sy769
Talked with Don about this last night. Pull the ECM and check the chip or else you could get the big kaboom.
I would say to try another chip from a local but I don't think I have ever seen a SyTy in Jonesboro. Well except for mine. :D
If nothing else pull the chip and I'll reprogram it for you or come to the Nats.
InvisiBill
If I remember correctly, 12.7 is the max the stock chip can retard timing too, so you may even have more knock than that. Definitely need to look at things soon...
93ty475
Re: 12.7 knock!!!
SYCOSIS said:
Don (#0112) discovered it had 12.7 knock on turbolink during entire run.
sycosis,
assuming you mean 12.7 spark retard, did it stay at a consistent 12.7 at all throttle positions or only when you punch it? im certainly not the expert but if its just stuck at 12.7, it may not even be knocking...or did you rack up major knock count?
servando
E-Rue
this is an easy one......
PULL YOUR PLUGS OUT AND LOOK AT THEM!
if they have silver fleck your 12deg is real..... if they dont who knows, but at least your not getting ready to blow it up.
e
