Whatever!!! :rant:TwinTurboV8Ty said:Although not my favorite I do like them on a ty, not as much on a sy but still good.
SYTY66 said:Looking for two rear 17x11 sawblade style wheels in the 50mm offset
dgoodhue said:As already mention HM never made Saw Blades 17x11 with a 50mm offset, your looking for a 91-93 ZR-1 rim. If you mixing and matching rims, 93 (and later) had a machined finish on them vs the 91 & 92 and would look out of palce
Sy-1177 said:Whatever!!! :rant:![]()
I also want to add that they never made a 50mm offset in the sawblades 11"rear. All the rears are 36mm which still fits pretty good imo, just sticks out a little more. The 50mm was a grandsport offset.
TYTILIDIE said:Really? I thought the saw blade ZR-1's were 90 and 91 only.
There is no rubbing on the cladding at all, but on full lock, the rims hit the control arms up front. The truck is lowered 1" out back, and probably around 2" up front.SYTY66 said:Does your tires rub on your cladding? Also is your Sy lowered? And if it's lowered, How many inches?
Sy-1177 said:There is no rubbing on the cladding at all, but on full lock, the rims hit the control arms up front. The truck is lowered 1" out back, and probably around 2" up front.
