1993 frame vin
sean
wondering where the vin is located on a 1993 ty. i did a search and the only thing i found was a 1992 vin location. i'm getting ready to pull the frame out so that i can paint it. i wanted to see if i can find the vin on the frame.
warmpancakes
Re: 1993 frame vin
above the fuel filter, its a "dot engraved" like the block, its also about the same size as the block stamping
sean
Re: 1993 frame vin
is that the only one? i thought it would be like the 92 on the rear passanger frame. getting ready to pull the frame so it can be paited don't want to grind down in the wrong place's
sean
Re: 1993 frame vin
is that the only place that you found the vin number's? if so i guess 92 frame's put there's in a different place than 93 did
