i need a new map sensor. can i switch to a 3 bar with absolutly no other modification, or should i just stick with the 2 bar till im ready for bigger mods?
you can do it, but it wont run for shit rob.
if you want 3 bar. go 3 bar chip. otherwise, stay with a 2 bar.
now if you want more control now, and want to raise the boost, assuming you have DM go with the 3 bar and the 3bar ultimate. (no 50# or anything fancy yet :wink: )
The two sensors use the same voltage range or whatever to indicate the 2 bars or 3 bars of pressure. It's not like the 2-bar sensor puts out 0-5 and the 3-bar sensor puts out 0-10 or something. They both put out 0-5 for the differing ranges (arbitrary numbers used for comparison). So your stock chip with a 3-bar sensor will see 15psi (full 2 bars) when it's actually at 30psi (full 3 bars). Likewise, a 3-bar chip would see 30psi with a 2-bar sensor at 15psi.
In other words, no. I have asked BG about doing a single T1-15 chip and/or porting the stock chip to 3-bar for people who weren't ready for/didn't need all the extras the Ultimate has. Probably be only slightly cheaper though, which people wouldn't want to buy anyway...
